Rear Window Washer Pump Location
johnemc
My tercel:: 1983 Toyota Tercel wagon 4wd
Post by johnemc »
I have a 1983 4WD wagon. in the front of the car I have a single reservoir for washer fluid and it has a standard pump with one outlet that feeds the front windshield wipers. there is a loose tube near the reservoir that feeds the rear washer nozzle but I cannot find a second motor. I also cannot see where the rear tube is supposed to connect to the reservoir.
can anybody shed some light on how this is supposed to be connected?
rer233
My tercel:: Multiple
Re: Rear Window Washer Pump Location
Post by rer233 »
Welcome aboard! My guess is a previous owner replaced the defective double-pump reservoir (or coolant overflow bottle- they're riveted together) with an assembly that only had front wiper/washers. You should also have a disconnected 2-conductor plug nearby.
In what part of the world are you located?
This is what u should see in a stock situation, johnemc. Hope that helps.
johnemc
Post by johnemc »
Thank you rer233 and dlb! That is exactly the info I was looking for. Now I know my combo coolant/washer reservoir has been replaced with one that did not have a place for a second motor. If I can't find the correct reservoir, I'll just tap into the existing one and mount a second washer pump externally. I'm located in Tallassee, AL. Thanks again!
Try car-part.com, it's a great resource for parts like this that you have to get from either wreckers or other enthusiasts.
johnemc
Post by johnemc »
already did - waiting to hear back from seller 👍
Good luck. I sold the one from my parts car, but that old plastic can get pretty brittle.
