Exactly what I've been afraid of with my wagon....too easy to get into a ditch in the winter....hit some frozen ground at the right speed and the glorified tin can metal that this car is made of will get crunched. Frame damage.....Typrus wrote: Its not pretty. I took off the quarter panel/fender and no appart upper frame damage, but the control arm mount is pretty well fried. I mean, you look at it itself and see no obvious bendage, but the stiffening bar has shown a beauty of damage.
Merrily we roll along, roll a... AHHHHH!!!!
Heh.. No other comments?
BLAST THE SNOW!! It has put me behind about a day, if not far more. I hope it thaws by the end of school tomarrow.
I thought the later cars had the higher diff ratios....?
Easiest to just change the basic engine parts?
.....keep the old alt/ext reg?
....keep the addons...carb....exterior stuff...other wise changing the alt/reg and PS will cause extra problems?
That way everything fits with your current wiring and ECU.....?
I'd replace the manifold gaskets while you are at it.....or at least snug them up.....
- My tercel:: None
I would discharge the A/C system and just take the compressor out as well as the condenser or whatever that thing is call that is up front. Unless, your A/C is ice cold and you need it for those long desert runs.
Putting a 3A-C from an 86 should be no different than transplanting a 84 3A-C, but I believe there might be some slight emission control differences, not sure.
2015 Honda Fit EX "Malachi"
I'm a little confused about which engine is going where...but the idea is the same...move the basic block/cylinder head...keep the peripherals as is in the destination car. Much easier?
86 Engine to 84 Body. Uhhh.... Is changing the carb necessary... I am already bogged trying to make this work in time. I'm also trying to load the manual again. The harddrive that fried had it. Ugh.. Alright. I have undone 4 tranny bellhousing bolts. Are there more? What else will prevent its extraction?
If you have a know/good carb...I'd try to stay with that vs one that's been sitting in a car unused.
3ACPower (or somebody) might know if there are differences. I know there are some difference between the 3A and the 3AC...the Fed and the Cal setups...but they still might use the same carb...difference emissions stuff?
I'm taking parts off of a '84 3A Fed to use with a 3AC Cal...some of the emissions parts are different for sure.
There should be no need to change the carb. If it ran good, that is. As soon as you take it off you're into changing gaskets and things that make the job more expensive.
There are 4 main (large, 12mm ) bolts between the bellhousing and the engine. There are also one or two smaller bolts that have to come out of the bellhousing. In addition to that you have the stiffener plates that go from the engine block to the front differential. Oh, and don't forget the clutch cable! Not that I'd ever forget it, I'm just afraid other people will!
Lol.. I didn't even see a stiffener plate? Well I got those 4 big bolts. I need to get some of the others from that gasket-like thin piece of metal between the two.
I REALLY REALLY appreciate the help you guys give.. It meas a lot.
How much extra work is it to replace the rear main? What extra does it entail?
The rear main oil seal I mean.
Don't know...but it's always a good idea to replace the rear main seal and the front trans seal (not so sure about this trans) when you have a clutch out...plus the pilot bearing...or at least lube it.
The engine is floating above the car. I broke a pressure plate finger pulling it (on the dead engine) so now I know what to avoid with removing the other engine. I would take pictures but the camera is acting odd. Still using my moms laptop as well lol.
Alright. Since the 84 has the external regulator, I had to keep the alternator. Since its mounting bracket is MUCH narrower than the 86's, I had to detach the compressor I just spent 10 minutes getting in (lol) and then remove the accesory bracket, go take it off the older engine, and put the usable one on my engine followed by the compressor and alternator. All hoses and cables are attached. The only thing left to figure out now is why I'm not getting fuel to the engine. lol. So far I have come, just to hit such a big obstacle. lol.
I also had to take a few vacuum componants and transfer them to the older body.
Do not detach your engine brackets from the top! Remove the bottom bolt! It sits in a U-shaped support that it tightens into. This also allows it to be easily removed or put back in. If you try to go from the top bolt, the inward angle will cause the bolts threads to be damaged in your muscling it out! Ask someone who knows! (lol) Also, only lift the engine enough to get it out of the mounts before lowering it slightly back down then pulling forward. This will allow the input shaft to be pulled BEYOND the pressure plate! If you just try to keep pulling it up, you WILL break a finger or 2 on the pressure plate! Again, ask someone who knows!.... Times 2! lol...
