Catalytic Converter
Catalytic Converter
How can you tell if your cat is plugged? When you push hard on the accelerator does it make a muffled noise almost as if there is a hole in your exhaust?
A quick and dirty shade-tree method is the "thunk test".
Roll the car up on ramps and climb under there. Curl your hand in a fist and hit the catalytic converter with the meaty part of your fist that makes up the pinky knuckle.
If your cat makes a hollow "thock" sound much like thumping a fender or your hood, it's good. If it makes a solid "thud" like you just hit a frame rail or something else rather solid, it's a good bet it's time to change it.
For comparison, give the muffler a thump. The cat shouldn't sound much different. Unless your muffler was like mine and rattled due to all the loose rust in it....
